Head gasket mod?
linemech31
NH
Just wondering how many ponys is the pealed head gasket mod worth for the 01 sxr700. Is a rejet required??
The 01 already has the tighter combustion chamber...i.e. higher compression.
Peeling the gasket alone is not going to give you any noticable difference.
higher compression doesnt require more fuel/oil. just a higher octane to prevent detonation.
Theres no steel head gaskets to peel(O-rings) on a SRX and the b gasket is only one layer, so I dont know where youd get confused.
you have to do more then just peel the gasket to feel a difference....peel gasket, reed spacers, bored silencer and clutch the thing.....now you will feel a big difference.
