Clutching suggestions
97srxXT
Michigan
1997 vmax 700
Hauck Tripple pipes
V force Reeds
One layer peeled on head gasket
Need some suggestions for what I should do for the clutching
Thanks,
Nick
mopar is it possible hauck made a set of pipes for the sx(r) and a set for the srx big bore ?
i recall selling a set to a fella in las vegas .
I still have the clutch set up for those pipes they ran peek 9000rpm
i don't think hauck has big bore pipes. i know bender racing does. the cpr pipes hauck sold for the sx-r, are to run at 9000-9200. you have a clutch setup for what pipes?
mopar they must have been cpr then , because i got a set of aeens and they look nothing like the ones that had the hauck stamp or plate on them , therefore i guess i got the set up for the cpr,
If your clutched to run at 8400 rpm with stock pipe your gonna be real close by just bolting on the pipes.
i was told to use 147.5 or 148.8 mains and 47.5 or 50 pilots. needles raised 1/2 clip and approx 2 turns on fuel screws. somebody, please correct me if i'm wrong.
