yamahaulinass
i have 98 srx 700 triple and im not to happy with it....it has a hawk prim and sec on it and hawk pipes(where it goes in to three little tubes and exits in three pipes... it just dont have what everyone says a srx should have power wise....its fast but not quik... and i HATE the powder bog but any help on geting this thing dialed in would be nice....
if it bogs in the powder your exhaust is likely to be getting blocked by snow...ive had this happen on my SX's a few times
yamahaulinass, Has I am sure you know that SRX's ( unless motors modded) Make better power with stock pipes and with minor clutching really improves the low end and top end speed. If not happy with it go back to stock pipe set up and find Turks clutching set up and I am sure you will be happy with it! I had a 99 with turks clutching and it would run with most higher CC sleds and never bogged or missed a beat!
Blue
Blue
Trade it in for an F-7.. You will be happier LMAO
here it comes...
tomseal6
here it comes...
tomseal6When's the last time you cleaned your power valves? If it's been awhile i might suspect a broken cable or a pull through. Start on the easy things like a compression test and go from there. What rpm's do your clucthes swicth at? on the 98's i think it should be around 8200 8300 rpm's then 8400rpm wide open
Honestly,
I would start by putting the exhaust back to completeky stock, putting stock clutches on it, cleaning the carbs, servicing the power valves, cleaning the power valves and inspecting for broken cables or power valves
Your powder bog could be
too steep a helix with not enuff secondary twist.
Hauck liked to use a very steep helix in his first srx kits. Worked well on hardpack but as soon as ya got in powder the secondary would shift out. What would happen is you would be stuck in high gear & there was not enuff backshift to gear down to 1st again. The bog seems like it is powder ingestion but it,s actually no backshift. synptoms seem very similar.
OZ_872
BenderSRX said:When's the last time you cleaned your power valves? If it's been awhile i might suspect a broken cable or a pull through. Start on the easy things like a compression test and go from there. What rpm's do your clucthes swicth at? on the 98's i think it should be around 8200 8300 rpm's then 8400rpm wide open
...X2
I like my piped SRX, It pulls like hell and sounds great too! But I hate to say it, I got better pipes than you, lol.
Triple X
98700, I think Yamahaulinass is talking about a Hauk silencer not a complete set of pipes. It's a wonder you get any help on here!
It says "hawk pipes(where it goes in to three little tubes and exits in three pipes"
By this it tells me he has Hauck pipes, which go into three little tubes (AKA Hawk Silencer)
My last post was a joke, But a true one, lol. All my advise had been given already....
marty f
power!!!!!
dude!!!!!!!! its out of tune there should be plenty of power,sorry there is alot of power there!!!!!!!!!!!
Also what Hauck clutching do you have?
yamahaulinass
hey guys i bought this sled with all this on it so im not sure what it is all i no is it has stock pipes hauck prim and sec hauck silencers and thats it! the rest is stock and the bogging is a BOG like go to ONE cylinder and barley stays running unless u keep it matted and when this happends it dont move.....but if u hold it wide open for like a minute it starts fluttering and acts like the other cylinders start firing....
start a new thread & tell us your exact jetting & needle setting.
yamahaulinass
its stock what ever stock is that what i have carb wise
Your way lean..jetting is huge out. keep driving it like that & smoke your motor.
yamahaulinass
ive ran it like ive stole it for 4 years now and i have had no problems with burning iyt up it just runs shitty
yamyrider
how do you know jetting is stock? what clutching is in it now....i buddy rides a 2001 srx and on radar last year he got a 120.1mph ....those machines are fast.
yamahaulinass said:ive ran it like ive stole it for 4 years now and i have had no problems with burning iyt up it just runs shitty
Then your jetting ain,t stock!
