I bought a brand new 1994 Vmax600 and then a new 1996 XT600 the 96 had the Yamaha recommened clutching and jetting updates with the additon of the older 1994(?) Yamaha headgasket to increase compression. My 86 Vmax540 had a purple comet spring with 1 shim to bring the engagement up to the Much needed 4200+ RPM range, the Yamaha recommened air box mod, a torque arm, 280/285 MJ's (be carefull below 10 degrees F) and both sleds had 96 woodys in the center belt. Time after time even with the 600's better stock track, which ever sled I was on, that one would pull the holeshot maybe, since I was 30+ lbs heavier than my brother ? Either way at the 100-150' mark the 540 would start pulling away and the father you went the more it gained ! 30, 40, 50 mph starts and any where on top end it was all 540 but, then you have to realize with the 540 Yamaha done something that was unheard of with the twin pipes..... and that was nail the pipes on the head so, well that Aaen, Decker and the other aftermarkets could not touch the stockers across the board ! I never put them on scales but, the 600's aways felt 75Lbs. heavier especially, on tight trails.
B.T.W. in 1994 I still had my 88 Exciter which had a Richards Pro pipe with jetting and clutching, torque arm, cold air intake, hyper hyfax with a frt. bend wheel kit and 96 studs. The Exciter and 94 600 were as close as any two sleds can be and the 600 was stock with the exception of jetting and 96 studs !
