size idler wheels on srx
7 and 5.125, you can use 7.5 rears and 5.350 on the small(6) skid wheels, this will make a big differance in rolling resistance and make your hyfax last a long,long time.
what bearings are in 7 inch wheel and in 5 inch wheel , 6205 or 6004 and are they both the same bearing
thanks dave
6204 small wheels
20mm i.d.on rear axle, I forget the number off top of my head
your right its 6004 small wheels
are you looking to replace the wheels with larger ones?
you use polaris wheels for a indy from mid 80-90, they will come with plastic bushings in them, you just use the plastic bushings from your stock yamaha wheels and the polaris wheels will then be a direct bolt on.
on rear wheels, the 7.5 yamaha wheels wereused on the 79 srx440, it is a direct 20mm i.d. bearing fit to axle, however on the newer srx youll have to take a 1/8th inch off the spacers on axle because theold bearings are just a tad wider, the axle wont go all the way into the outside wheel where your axle nut goes on, just take 1/8th off and it fits like a glove.
here is some 5.3 inch wheels they are close but work great.
patsxr700 said:
Hey amato sweet set up dude and sweet looking sled you got there!! ;)nice work
thanks alot i am busy getting it ready for snow. let me know if you need any help. welcome to the ownership of a awesome machine. the legendary srx.
