How does this wash look?
98700
Wishing for snow!
Hamilton, Ont
SafeRedirect.aspx
So???
I think it looks to be really close to dead on, if not dead on?
1st one is rich
2nd one is good(close enuff)
3rd one is the richest one.
A pencil eraser size clear spot at the transfers is perfect jetting.
Ok that's great. Thanks a lot man! You really are a wealth of knowledge!
Know anything about heads?
daman said:
that is correct.
Thank you also, I have 155 mains in there now. I'll see what I got for jets, But I think it might be ok. As I rode in cool weather, not the COLD weather I ride in Usually.
check your jetting(wash)in the temps you usally ride in,do a full throttle
pull for about 100 or so feet then hit the kill switch pull plugs,then do the
same for each circut,low,Mid range...
Will do when more snow comes!
Would either of you two know anything about heads? Preferably The squish, squish angle, Band width??
Sorry,i'm a stock kinda guy, somone will chime in there for ya,hang in there..
Oh I see how it is, lol.
I don't have much time to get some head info. They go into the shop on Monday, LOL!
100 feet of wot won't tell you squat. you need to run it wot for 6-9 sec, which would be 600-1000 feet. you could back down on your main jets 1 size and still be ok. your wash is rich.
I said a 100 OR so.....that's all i ever do and it works out just fine, thats all ya need
if your lean to start you could smoke her if ya do a long pull,,,,ya start off small at least i do...
100 feet would be covered in like 2-3 sec from a dead stop. what ever circuit you are testing, be it the pilot, needle, or mains, you are not at that particular throttle position long enough, to get an accurate plug/wash reading. you say if you are too lean, that you could smoke it, in a distance over 100feet? that's why you always start like 2 sizes fatter than needed, so while testing, you see how rich you are, and you back down from there. always better/safer to start rich. you also said that you use 100 feet of wot for your testing? what are you testing? you say you are a stock guy, so what would you be performing jetting tests for?
daman said:
you still need to keep an eye on jetting what ever your running,ok boss??
temps ,alt. changes.....
i know, but if you're sled is stock, and has stock jetting, and you ride by home, why would you need to keep an eye on the jetting? what is going to change? no mods = no jetting changes, not leaving home altitude = no jetting changes, and yamahas good jetting = no jetting changes.
I'm with daman on this one. better to be safe then sorry...
daman knows all, even if hes running stock sleds like me, he still knows his way around the block.
