viper front shocks on 2000 srx
dave carpenter
Timmins Ont
looking at buying viper front shocks for srx because i long traveled it just wondering if i can mount viper shocks or do i need anything else if so doea anyone have pics or instuctions how to and will it help front end
thanks dave :letitsnow
they dont mount the same, the vipers dont have a upper eye like the srx does, i think bethviper used to make a mount but dont know if he still does.
well will see if its easy or i heard you can order viper top mount but not sure if it is possible or what else is needed to mount shocks on srx
help please dave
ithink that will work on sx not on srx ,boes nto have same top mount for shock
prob need something else fos srx to mount viper front shocks ,anybody
dave
I have a set of take off shocks from my 07 GT phazer with just over 1000 miles on them.
They fit on a srx. make offer
how long are they ,and they have top eye bolt just like bottom mount,like the srx
thanks dave
They are 15 3\4'' long from eye to eye. Yes they are the same mount like the srx. I just had them on my brother's srx to see if they fit because he had got fox flots for the phazer to put on his srx.
so how much did it lift the front of srx when you tried them on there
dave
Im not shure how much it lifted the sled, but you might have to rebuild them because that is a heaver sled.
Zac
dave carpenter said:
well how do you know if it needs rebuilt and how much to rebuild
Contact BETHEVIPER on this site he will steer you in the right direction to do the job right, he has acutal knowledge you want to listen too not like some posted above. If you need a set of Viper shocks, PM me I have a set of 02 take offs(New)cheap because they would need revalving.
What ExpertXViper said, here is the last I heard from BeTheViper. Go to Tech Frequently Asked and reply to sticky "interchange on suspension parts"
If you want to run Viper shocks on a srx, you need the proper brackets like BeTheViper has made or you "allegedly" could replace the bulkhead that the front upper shocks mount to with one from a Viper or SXR. I'm not so sure about the pipe clearance w/ that change tho. :winterrul
well ordered new brackets that lower shocks 1.5 inches im gooa try that first ,then maybe longer shocks later will find what the best way to go
thanks dave
viper shocks will not work on front, i tried it and installed a spacer on top to bolt the u end together but the shock was 5 inches longer than the srxs and you cant get enough adjustment from the front arms to line it up.
thanks dave
I would highly recommend talking with BetheViper. I long traveled my '01 SRX with Scott's brackets (they extend the top of the Viper shock up into the bellypan). He was my one stop shop for the radius rods, tie rods, shocks and trailing arms (my original T-arms were bent).
I made some plastic covers for the bellypan cut-outs and some spacers for the sway bar and am now in fat city. I only wanted to do this once and if you're looking to do the same, talk to Scott.
