srx 200 rpm to high
cwcsrx700
N. East lower MI.
Running a 48/40 advant with green at 60. WWW primary new 8dn20's with 4.5 both holes. Its hitting about 8600-8700. Whats the best way to get the rpms down to 8400-8500? Washers on the rivits? What would a BWB primary spring do? Adjustable weights are not an option at this point. All parts seem to be in good shape and alignment is good.
Toss a 1 gram washer under both rivets. should net ya 8400 rpm.
Getting good bite with 192 studs and about 8300ish outta the hole. The overrev is from about 80mph+ in 40f weather. Turk are you getting these washers from a hardware store or are these special washers from a go fast shop?
do you have like a 48/42 helix to try? i think your finish angle on your current 48/40 helix is too shallow, thus holding back the shift of the secondary at top end a little too much, and thus giving you 200 rpms over-rev. i believe if you try a helix w/same initial angle, but 2 deg more on the finish angle, you will hold a 8300-8400 on top end.
