sledwrecker
I have an '01 700 and the temp light keeps flashing in intervals of 3. Anyone know what this means?
Is this upon start up then stops or just keeps going and going when the sled is running??
billbies
if its a long flash then 3 short flashes its something to do with the water temp sensor I was told, if its one long then 2 short I do not know
Hope that helps
Bill
Hope that helps
Bill
Yamidude59
sledwrecker
I know upon start up it flashes 3 times for diagnostic. After that, it keeps flashing the same. 3 short flashes, stop. 3 short flashes, stop and on and on. I was told it was a temp sensor. Sound right?
Loctite2
My Viper did the same and all it was was a loose wire connection in the plug to the sensor. Wiring can be tight to the plug. Make some slack when checking the connection.
