do I have to split the crank case or
..SNAKEBIT..
NE IOWA
should I tear the motor completely apart?
took the center piston out
cylinder looks like it was hot all around
piston melted exhaust side off and rings came aprt & hit head etc..
I think the cylinder will clean up fine, but piston is needed
do I or should I split the case and what should I look for if I do?
never had the bottom of a 2 stroke apart before, have done several top end rebuilds. Was thinking maybe I should pull the bottom apart and do seals etc.. and what else should I check if I do tear it apart.
PS. 2002 viper w/peak head and CPR pipes
did the piston explode?if so my all means.it is super easy to split the bottom end!the only somewhat specialized tool needed is a steering wheel puller to get the flywheel off.i would recommend it to do the seals if they havnt been done before if nothing else.imo
split the case, but the crank seems stuck in the upper half?
dont want to us the BFH so any recomendations?
it really seems stuck it there or am I missing something
