what are most people running for belts? hard compound or soft? OEM or aftermarket? i will be running Heelclickers set up for Aggressive upshift.
mopar1rules
if trail riding, use the oem 8dn belt. the aftermarket ultimax belts suck.
what about drag racing? same belt or different?
mopar1rules
drag guys like to use the soft belt from what i've heard.....better belt/clutch grab. i believe the soft belt is the yamaha 89L belt. the 8dn belt is a harder compound, but has long life, so its oriented well for trail use.
valin
8CH is also a nice, soft belt for drag racing. I am not sure if you can still get them though....
Don,t use the soft belt with heelclickers. 10X more chances the belt will explode which takes out the weights then kiss both clutches good bye
YAMMIEGOD3:16
8DN ALL THE WAY 3:16 (yammie tony)
Danger Dog
A soft compound belt will be eaiser to make the clutches grab but it is not the fix to poor clutching. You should not have a problem grabbing the belt with clickers unless your setup is way off. I had a ultimax 3 snap on my stock srx on the lake. Luckly there was no damage to the clutches. I think it was a combination of the belt was tired and I ran it way longer distance then I was geared for. The 8dn may of done the same. I do run the 8dn on both the stocker and my 1000 and no issues with it so far.Yamidude59
I run 8dn... They last a long time if broken in properly...
8dn..
