what are most people running for belts? hard compound or soft? OEM or aftermarket? i will be running Heelclickers set up for Aggressive upshift.
mopar1rules
if trail riding, use the oem 8dn belt. the aftermarket ultimax belts suck.
what about drag racing? same belt or different?
mopar1rules
drag guys like to use the soft belt from what i've heard.....better belt/clutch grab. i believe the soft belt is the yamaha 89L belt. the 8dn belt is a harder compound, but has long life, so its oriented well for trail use.
valin
8CH is also a nice, soft belt for drag racing. I am not sure if you can still get them though....
Don,t use the soft belt with heelclickers. 10X more chances the belt will explode which takes out the weights then kiss both clutches good bye
YAMMIEGOD3:16
8DN ALL THE WAY 3:16 (yammie tony)
Danger Dog
Yamidude59
I run 8dn... They last a long time if broken in properly...
8dn..
