sickric
Hey guys,
I am taking both the vipers to a radar run / drag this weekend, never did it before, I have 2 stock 02 sxv' s studded w/ 192 and the other with 144 running premium fuel and installed tether cords, low profile windys. I do have an aftermarket sno stuff can that might sneak out a few more ponnies, but otherwise these sleds are well maintained , basically stock, We are looking for rider positions , weight shift, how not to spin out on a hole shot , etc, can anyone give us some pointers ? we just want to be safe and go have some fun and ride WOT !!!
tedgoesfast
roll out till you know it will get traction then hold on but there is alot you can do suspension etc tie down front and rear
Not on a Viper it won't. I'd run stock personally or triple.sickric said:Hey guys,
Get rid of the premium fuel & run regular.
wifesviper
I was going to ask that question.I've been running premium but regular is fine??? Sorry for hijacking your postTurk said:Get rid of the premium fuel & run regular.
radar runs and drags require to totally different set ups.
harness racer
1- 96 studs is plenty helps reduce rotating mass
2-do not tie it down , you will add new pressure points on hyfax and slow you down
3-regular fuel if you have stock heads
4-roll out smoothly keeps clutches cooler
5-tighten transfer rods some , reduce the transfer a little
6-elbows in , knees in , head down , tuck as good as you can and stay still,
7-try to warm your pipe up without fueling your engine up ( use the stand if they have one )
8-have a blast !!!!!!!!!!!!!!
akrievins
When you guys say regular fuel, do you mean like plain old pump fuel as opposed to race fuel, or do you mean 87 octane instead of 89,91, or 94???
The Viper calls for 89+
I'm not understanind why you'd run 87 instead of 89,91,94?
harness racer
its a easy way of jetting down so to speak , the lower the octane the hotter the burn , dont try this on anything other than a 2000 ft. or less radar run . NOBODY IS TELLING YOU THAT ITS 100% SAFE , BUT SIMPLY THAT IT WILL MAKE MORE POWER!!!!
sickric
Hey Thanks for all the feedback !
