liveride777
I would like to get some bar risers for my 02 viper for a better bar position, but im wondering how high is to high with the cables and how much slack they have. Does anyone recommend a certain company for bar risers? ROX, speedworks are a few i have heard of.
thanks
thanks
dirtjumper895
I put a 3" pivot riser on my mtn viper. stock cables. it is made by powermadd
ryanryan
I wouldn't go over 2" with stock cables.
sickric
I own 2- stock 02 vipers ;
1 has a powermadd 2 in riser block.
The other has a 3 inch ROX pivot riser.
both work fine with stock cables, no binding,or stretching, I also put on seat risers to bring up the riders position.
Both of the machines feel & ride fantastic.
liveride777
thanks for the advice. Ill post some pictures when i get them.
I recommend a pivot style. Moving the bars forward helps almost as much as raising them. Doing both is great. I like the 3" with stock cables, but you have to re-route some of the cables. Be sure to check cables turn to turn, not just straight ahead.
Im with Ring-a-Ding!!
I went with 3" Rox pivot and really like the hight and the fact that they are more forward.
I had the powermadd, but they wouldn't hold their posision. I kept tightening the bolts untill I snapped the riser
Thanks for ringing the bell sir !!!
tremorzrt
Here is the riser I used. Worked well with stock cables. Mine is the 35 deg.
http://cgi.ebay.com/ebaymotors/ws/e...0287339633&sspagename=STRK:MEWAX:IT&viewitem=
WNYViper
I used one of the TruVert 3" 35* risers (link posted my tremorzrt) on my Viper, I went with longer cables, the stock ones seemed too tight when steering left/right
richierich
If you want the most height with stock cables a 3.5" rox pivot riser is the best choice.Or you can go taller with other cables.Heres some info if you need anything.rich
http://www.richmotorsports.com/store/view_product.php?product=ROXK777Q87
3.5" riser=$85
long brake=$50
long oil,gas=$75
3.5" riser=$85
long brake=$50
long oil,gas=$75
in my 02 i picked up a 3 inch riser block at haydays for $5.. it seemed to be too much for the stock cables so i cut it down to a 2 inch.. this works fine but wouldnt mind more! but this will have to do without spending $85-$200 for taller riser and with longer cables
liveride777
http://www.denniskirk.com/jsp/tpl/p...d=31402&skuId=592884&productId=p592884&mmyId=
Do you think these will work? I was thinking just a 2 inch block for now?
liveride777
http://www.speedsupplies.com/accessorylistingdetailpurch.asp?item=27982
with this fly pivot adapter i think everything will work out all right. Any comments anyone?
I put the 3 inch on my viper!!! it worked well...
Hey Guys I Like The Looks Of The Truvert Anyone Know What The Different Angle 15deg Or 35deg Does. I Looked At The Pix I Cant Tell If It Moves The Bars Forward Or What. I Know A Few Guys Are Using Them And I Think Im Going To Get A Set But Wanted To Se What The Thoughts Are. Thanks
2inch is wat i have on mine wouldent go any higher with stock cables
liveride777
does 2 inch make enough of a difference?
