marty f
anyone know which citgo two cycle blend that yamlube is?????
are you 100% positive of that? Because according to citgo's website it isn't even rated TCW-3. But it says that the superguard marine is for high performance liquid cooed engines. please elaborate on that for us.daman said:citgo sea and snow is the same as yamalube..
Contact:swmichsx said:i sure wish i could find sea and snow around here. i have looked at every store i have been in and nothing in the niles michigan / south bend indiana area.
yammy said:are you 100% positive of that? Because according to citgo's website it isn't even rated TCW-3. But it says that the superguard marine is for high performance liquid cooed engines. please elaborate on that for us.
horkn said:FWIW, the W in 4 stroke oil, say 5W-30, actually does stand for Winter. Obviously in TCW3, it means water cooled.
Dave M said:You know that...I know that...and several others know that.
But the all mighty one was preaching that in his mighty thread..... sorry lost alot of credibility for false information.
Dnrtheil said:The "W" in 5W-30 stand for winter?!?!?! Is this sold right next to the summer time blinker fluid?
Derek
Dave M said:From Wikipedia...
[edit] Multi-grade
The SAE designation for multi-grade oils includes two grade numbers; for example, 10W-30 designates a common multi-grade oil. Historically, the first number associated with the W (again 'W' is for Winter, not Weight) is not rated at any single temperature. The "10W" means that this oil can be pumped by your engine as well as a single-grade SAE 10 oil can be pumped. "5W" can be pumped at a lower temperature than "10W" and "0W" can be pumped at a lower temperature than "5W". The second number, 30, means that the viscosity of this multi-grade oil at 100°C (212°F) operating temperature corresponds to the viscosity of a single-grade 30 oil at same temperature. The governing SAE standard is called SAE J300. This "classic" method of defining the "W" rating has since been replaced with a more technical test where a "cold crank simulator" is used at increasingly lowered temps. A 0W oil is tested at −35 °C (−31 °F), a 5W at −30 °C (−22 °F) and a 10W is tested at −25 °C (−13 °F). The real-world ability of an oil to crank in the cold is diminished soon after put into service. The motor oil grade and viscosity to be used in a given vehicle is specified by the manufacturer of the vehicle (although some modern European cars now make no viscosity requirement), but can vary from country to country when climatic or mpg constraints come into play.
So yes it does stand for winter....just does not mean much.
Here is the link... under 5.2 multi grade....winter
Derek
Why would you use Citgo oil???Do you guys know who owns citgo?? Even if it has all the appropriate designations, TC-W3 and so forth,this is more than enough reason not to use that crap.I will not support venezuela.Am I wrong for posting this?marty f said:anyone know which citgo two cycle blend that yamlube is?????
