PZ 1 said:I am going to be making a Venture/Phazer hybrid. I haven't gotten into it yet, but had assumed that the Venture chaincase bolts in the same way. The
Venture jack shaft will have to be used. You would have to cut the hood for the reverse lever and there may be interference with the fairing and the lever. I will be using the Venture hood and the Phazer fairing and windshield. The fairing and/or the lever could be modified for clearance. Also the fairing and steering can be raised with a riser block which I will be doing anyway./QUOTE]
Let me know how it turns out. I am very interested.
BlueIronRanger said:Just for a referance I went and looked at a 97' Phazer II Mountain Lite yesterday and It had Reverse and Electric start on it from the factory. If I remember right they changed to a different style chain in 91', I'm not sure if the cases remained the same between 90 and 91. If I get this 97' I'll compare the chain case to my 90.
Daring said:Will the newer chain cases work on my older sled? =To put reverse on you'll need the jackshaft and chaincase setup. Are you still making those kits to widen the Phazer? Sure, I have the material to widen the T.S.S. Sleds just need to know the C to C you are going to.
PZ 1 said:I did not remember the Mountain Lite having reverse so I checked the sales brochure and the parts list and it did not. The reverse on that one must have been a retrofit.
BlueIronRanger said:Or a dealer install. The guy was the original owner and said it came that way from the dealer, looked to be done from the factory to me anyhow. I should have pulled the trigger on this sled, it only had 770 miles on it for 1350$, cheap for a 97' with E-start and Reverse. Now I found a 93' with 2500miles on it for 950$ OBO, no e-start but thats extra weight! Hard to find these Longtrackers around me.
