Bender transfer rods
BLUE DEVIL 700
Cape Breton,Nova Scotia
does anyone have the instructons for installing Bender Transfer rods,i got a set of used ones but no instructions.just want to make sure everything is included as well.
HAPPY NEW YEAR EVERYONE!!!! :letitsnow
Give Bender Racing (716-941-5840)a call they should be able to help you if not I could email you the instructions if I still have them.
yeah they r easy i did about 5 sled withs rods only hard part is putting the skid back in :P u knoly have to take off 2 bolts that hold the rear part of the skid then u can heat the bearing by a heat gun... thenn just get a 2x4 and hammer on one side of the shaft then it should pop off u dont have to worry about the other side pull the shaft right out might be alot of greese but whach the 2 washers on each side and the bushings :P once you pull that shaft out both rods will fall and u have to take the bolt off the bottom of the rods and the whole rod will come out... once u have it out u have to take the bolt off the bottom of the rod and put it on the bender rods... torch that bolt seems like yamaha like locktight in that area lol then just go backward from there haha
I beleive they just install onto your old rods. just remove the 2 bolts on both sides and install, you may have to remove on back wheel and slide the other over, and loosen the track. its very easy.
bump
Anyone have a set of instructions they could email me? In the same boat as the OP, bought a used set. I know how to install them, but was curious what washers where and what height of the adjusting nut to start with. Thanks.
