gearing help
900 ft. race, drop one tooth on top, set secondary to 50deg. Maybe think of putting in studs, 96 is fine. drop one layer on head gasket.
I think one is enough for 900 ft. I wouldnt drop two teeth cause the chain angle on top would be to sharp, without changing the bottom too. Doing the trail perf clutching setup in the tech pages would help too. you will be suprised how much one tooth and the head gasket mod will do, just make sure you use good gas. check rear suspension, make sure its square, Drop your jetting 1 step on the mains too, check your plugs, but you should be fine.
