Got an electrical problem on my Viper. Obviously I will double check the harness under the motor, but I don't think it's the issue as i checked it last year and had not issues. Also made sure the routing was no where near the motor.
Situation is this:
1. Driving down trail with bar warmers on, if I switch from hi beam to low beam (or via versa) the tach will reset (goes off, then does startup sweep) as if the power is interrupted? Same thing happens at idle if I pull the brake level (but only at idle, not at trail speed).
2. If I turn the bar warmers off and drive down the trail switching hi to low, the tach is fine (does not reset). Same if I pull the brake. However if I switch from hi to low at idle it will reset and the brake will also cause a reset.
It almost as if there is not enough power to keep everything running? Any ideas for other potential causes? Should also mention that the bar warmers did not seem to be giving off the usual heat (if any at all).
Thanks,
Bruce
Situation is this:
Thanks,
Bruce
