Grip warmer, 1 blink
liveride777
NOrthampton MA
I was riding this past weekend and my warning light came on and blinked once. So i looked at the sheet in the tech section it says my variable resistor is disconnected. I looked at everything and it seems ok. Could this be the start of the wiring harness wear through underneath the motor?
Also, i had read a post about the key in the disc wearing, causing excessive play in the disc. Mine seems to have to much play. Sometimes when i hit the breaks hard you can hear the disc "ting"
Thanks for the help
what lights were on warning and what other? or was it just warning? and you sure it was just one flash??? just trying to get a better handle on it.
yes it was just one flash of the warning light. And i looked it up it said it was the Variable Resistor for the hand grips, disconnected. everything seems to be working fine, and the connection seems fine.
I was riding in some very powdery conditions if that makes a difference. Maybe a connection got wet?
