Clutching question for radar runs
Sno_Racer_Xtreme
Maine
i have an 01 srx 700 that is trail ported from bender racing, also other ods and ends on it. I have been doing some 1000' radar runs and now there are a few coming up that are 660'. this sounds way too easy, but is it possible that the same clutch setup will work if i only change the gearing for the distance, or will i have to rework my whole clutch setup as well??
Sno_Racer
If you lower your grearing it might over rev, you won't know untill you try it. If it does and it is not by very much (100-200rpm) just add a one gram washer to the tip.
