oil pump not working may have air in it how do you fix it?
hitman747rtx
ney york
i have a 1999 vmax sx 500 rust rebuilt the top end, i put about 80 miles on the sled with oil in the gas tank to brake it in but not seeing a oil drop in the oil tank any ideas????? would rather not have to rebuild this motor again.... help... :o|
Remove bleed bolt let oil drain,also make sure pump arm is working and not
off. when sled is running pull up on the pump arm so it goes to full flow pump for a wile.
then when done set pump.
