Help Please!!! 03 Viper Ratcheting Issue
binracin
up state ny
Hello, i just put a 1.25 predator w 96 studs down the center.The sled is bender trail ported, tripple piped, head mod, carbs bored, clutched etc... I have to tighten the track up as tight as i can get it. it still ratchets when its hooking real good. the teeth on the drivers werent that bad but i pressed them off and turned them around still not n e better!!! can some one help me please? its driving me crazy thanx
you might need extroverts .....i hear that ski doo extroverts are like 20 bucks compared to aftermarket ones being like 100 bucks .....
thanks for the info but which ski doo? or r they all the same and my track came off a mxz 600 1 clip every four holes with two closed holes in between the open holes. does every hole have to b open to use extroverts?
Tracksusa has a good price on extroverts, They are the ski-doo ones. I put a set on my Viper last year, because I got tired of the racheting too and I didn't even have studs. Yes you need every window open! I have heard of people cutting the closed windows open,but you might want to ask around more on that one. I would think it would work.
I wonder if it would work if you modified the extroverts?
Say on a 9 toothed one grind down the extrovert tip on every third one so it should line up with the closed windows in the track. I would think that the other 2 teeth may still be engaged.
Just a guess though so maybe someone else that is a track/ extrovert expert can chime in...
binracin said:
thanks for the help hatch! will i need to have a clip every hole?
depending on riding conditions and style, no. quickest and easiest way to punch the windows is a sharp chisel over a block of wood. buy a couple of chisels, 1 for the window width, 1 for the lenghth. clean the corners out with a sharp knife. its labor intensive. as for the clips, if you can borrow a clip tool, great. if you have to buy one, bend over. while your bent over, price out clips.
i woulndt even attempt this!
Thanks I wasn't sure if this would work or not. Spacing wise with the extrovert teeth and windows should be OK but now that i think about it if it were to ratchet you'd be in trouble...
Just open up the windows with a utility knife or a something similar and go ride it. Don't need to bother with clipping the now open windows, but you can if you want too.
