renos2
looks like the classic lean burn/detonation,,air leak,crap gas(too low octane) were carbs cleaned? jetting checked,what kind of gas used? ethanol??
renos2
carbs were cleaned at start of season and just gased up at local gas station were i always gas.I have about 500kms on this season with no problem
the center starded burning too
renos2
can you tell by the wash
piston top look weird like they are ready to burn.....and look very low oil burning with no wash .....
They all look peppered to me. Had some detonation going on. You got gas issues or the ATACC got you after a stop.
renos2
do you think a crank seal could cause this
no ... cause all those cylinder are ready to go caboummmm...make sure your carb are clean and make sure it run with oil
renos2
have you ever heard of attac screwwing up
what is attacc???? your sled seem to run lean
renos2
it is a altitude compensator that ajusts temp and altitude automaticly
Through the years there have been some guys that have had problems with the temp a flow causing them to slowly eat pistons. What happens is they ride; stop for a dig out, bs, smoke, etc...; jump back on and away they go. What happens then is the compensator warms up due to the sitting and thus leans out the jetting. 2 miles down the trail it's cooled back to whatever the temp is and is working right again. Since the ATTAC is basically a temp a flw with an altitude comp too I'd assume that the same problem is possible.
Now before all the guys that have been running compensators for years without problems get all bent out of shape. Notice I said some guys. Been lots that have never had an issue and probably never will, but they ride differently than the above, or make an effort to not let the comensator over compensate.
dump the tempa blow!!
renos2
checked water pump today and it is all good so Im leaning toward compensator screw up
mopar1rules
daman said:dump the tempa blow!!
X2!!! if you got crappy gas w/ethanol or something, and the ATTAC leans it out more, a engine disaster is for sure in the works.
mopar1rules said:X2!!! if you got crappy gas w/ethanol or something, and the ATTAC leans it out more, a engine disaster is for sure in the works.
put that attac shit in garbage .....save u money on gaz but cost u a motor
SRX500_129
what type of airfilters are you using?
the biggest problem with lean mixture comes from the airs way into the carbs.. there is a lot of people that doesent understand how importen this is. the airbox most be mounted perfectly!
