Haven't had the SRX out since last weekend.Started it up today to circulate the water and see what happens.As soon as I started it up,I removed the rad cap to look.Water is moving.This is normal,I understand that the thermostat will let a little coolant thru before it really opens.So if coolant is moving,means the pump is working.Now the question is..is the coolant moving at full open position or not.I let the sled idle for 15 minutes at least.Left running board exchanger is warm,rear exchanger is warm,right running board exchanger starts out warm and at the middle to end(towards the motor) it feels cold.So water is not circulating right thru.I guess I will have to open up the thermostat housing to check.I am ordering new parts for this .So the SRX will sit in the shed for the next 2 weeks I guess until parts come thru.
QUESTION: This has to be the problem,what else could it be.
