I took the throttle block stripped it down and put it in boiling water for about 30 secs to soften it up. Had the 07 bar lubed up with oil and then rammed on the throttle block. Made a small crack on the block but that is no problem. Took out my plastic welder kit and its as good as new.red rider said:How did you guys get the one piece throttle block over the grips?
