dirtjumper895
Hey all-
I am going to build myself a set of tubular trailing arms, however i am having a a hard time selecting what diameter of tubing to make them out of. I was wondering if anybody has some from northern lites or MPI of fabcraft, if they would be willing to post up the tubing diameter and thickness used.... I do not need the length's of them, unless you all feel like measuring that too.
I was thinking for the ones i was going to make i was planning on using DOM Steel Tube, 1.25" probably 3/16" wall for the head, and then make the main tubes out of whatever size will telescope inside the 1.25" tube. Running a threaded heim joint in the rear mount end.
Thanks for any help or input.
Dave M
Are we going for the
Because if you use DOM tube you will probably be heavier than the stock trailing arms...
3/16 wall tube..is heavy for that size.( if they even make it that thick, that small ) I used to stock .120" wall DOM from 3/4 -1.75" tube..... I think I got my hernia from that stuff. Chromoly is the way to go... Stronger, so you can run thinner wall = much lighter... and does not rust as bad...
???Because if you use DOM tube you will probably be heavier than the stock trailing arms...
jwiedmayer
jwiedmayer
The bling will be expensive if you use 3/16. The first time you hit something hard engough that the trailing was supposed to bend you will have a bent up tunnel. Other words don't make them any stiffer then the stock ones.
Dave M said:Are we going for the???
