2000 yamaha srx parts on 1998 yamaha srx
xviperx7
Wiscasset
was wondering if all 2000 yamaha srx parts would fit on 1998 yamaha srx hood running boards skis trailing arms and skid plate all fit?
yes and no ... u will need to modify the lower case to hook up the 2000 pick up coil
your wire harness has 3 plugs on the 98 and only 2 on the 2000 you could change the complete harness and drop the 2000 motor in plug it in and go!! that way you would have the dcs on your 98 also
its not that big of a job you already have the engine out so really all you need to take off the sled is the gas tank and the seat, remove all wires and install the 2000 harness in it... you can get one from e bay for a hundred bucks or maybe cheaper depending where you live
hey i have a 2000 harness for $75 if you want it, also let me know if you are still interested in that track and shocks, your pm box is full
I thought DCS only came with the 2002 ?
