Just picked up a psi pipe for a phazer. What is the difference between the one that exits out the stock hole and the one that you have to cut a hole in the pan for?
Nikolai_Ex
Hmm i did not realy understand your question.Does your pipe exit the stock hole?i you have to cut a new hole,you may have the wrong y-pipe
I have a PSI on my phazer and it went out the stock hole.....
srxbully
probably isnt a psi but maybe a aaen or bender? never heard of a psi going out a new hole.
I'll try to post a pic later. It does say psi on it. fits fine everywhere except at
the end, needs a hole about 2-3 inches behind stock hole.
Nikolai_Ex
And you are sure this one is for a phazer,and not a srv?
JeffroPZII
I just had the PSI pipe off my Phazer II last week....the pipe curls back to exit out the stock hole....
djrascoe
Is there anywhere that sells good used phazer parts? Id love to put a pipe on my phazer, but i sure dont want to pay a couple hundred bucks for a pipe on a '88 phazer. Especially since I'm getting a new sled next season.
srxbully
^^ i have a psi pipe for sale.$75 plus shipping & it's yours
elcoy
You still have the PSI Pipe for sale?srxbully said:^^ i have a psi pipe for sale.$75 plus shipping & it's yours
elcoy
phazerguy said:I'll try to post a pic later. It does say psi on it. fits fine everywhere except at
I had this also and found out the pipe was actually for a exciter. I have three phazers all with PSI pipes they should have a return curl at the end so it goes out the stock hole
what jetting r u running with the psi pipe?
elcoy
I am running the follwoing:
MAN102/221 152.5 jet
YA90501-520A9-00 Compression spring
YA8VO-W176A-00-00 Weights
what alt. do u run at?
has any body did the carb mod to needle? how does it work
elcoy
I run Stocktowman said:what alt. do u run at?
elcoy
I did not change my needle just the jets. Did someone tell you that the needle had to be modified?towman said:has any body did the carb mod to needle? how does it work
There is no needle in those carbs. do a search on the phazer carb mod and you will be able to find the info you need. What is your riding style? Aggressive or do you do a lot of slow riding? If you stay out of the midrange you won't need to do anything but change to mains and maybe pilots. I ran 105 pilots and 147.5 to 150 mains and never had the sled burn a piston and thats with a ported engine.
Buckzone101
You still got that pipe u had forsale?
journeyman
If it is a PSI pipe it should exit out the stock hole. PSI did build a set of twin phazer pipes but that was a different story in itself. Now AAEN built a single pipe that exited out the stock hole called the Quiet can for trail use and they also had a Race pipe that did exit out the side panel which needed to be cut. That pipe was for a race ported motor only and was loud too. Hauck used the Race pipe on his improved stock Phazers years ago.
