since it is warmer out and the snow is more heavy,I have lost about 400 rpm wot.have red spring at 80 with stock SRX helix(47).Primary is loaded with 4.5 in each hole with y-w-y..all stock setup.Should I increase the wrap to 90 with red or try green at 80.Was hitting 110mph today at only 8000-8100 rpm at wot.Though I could smell belt burning when I punch it from start.Perhaps it is slipping in secondary.Belt is within specs yet at 33.50 mm.Today the temp was about 34 F. New belt is 34.50,wear limit is 32.50.I am in between.I have 3 new belts sitting here,but not going to use them this season.
