mpi srx billet heads
jordan
saskatchewan
hey has anyone here run the mpi billet heads or other brands and if so how do they like them and if anyone has one they wanna part with i may be interested
i don't think anyone really ran the mountain performance peak heads on their srxs. usually guys just stuck to the stock heads, w/machine work, or they ran megapower heads.
amatosrx said:
i run it i like mine.
Looks like you run Aaens as well. I have a Peak cylinder head from Mountain Perf on my 2002 SRX , with Aaens as well. I have the 24cc[actually 23.75cc]inserts, stock is 26cc uninstalled. I like them...I also have a couple sets of Stock heads that have been machined for different comp ratios . The Peak head is a little more convenient for machining + changing compression ratios, but anything you can do with the Peak heads can be accomplished with machining the stock ones. [They do look good !!]
JMO
ok so say i guy burns up a piston when you have those billet heads would you just have to change the dome or would you have to replace the whole head assembly
mopar1rules said:
just need to replace the dome.
...x2
If you pick up a Peak head I would recommend you also get a spare gasket set[they are actually O-rings]. The sizes can be a liittle tough to find if you need one ASAP. Been there done that!
I have heard the Mega Power heads were good as well + was told Hauck's heads are NOT the same as the Peak heads + the domes do NOT interchange.
