hotbeek
Don't you guys have wives or girlfriends ?! Let them practice "tuggin' on your rope" the first 10 times !
LOL ! My wife reads this and I won't need a block heater, I'll be out there sleep'n with the sled !
xactly what I experience....
I could almost tell you the temp outside by the number of pulls. One hour after a run at minus 20 c, two pulls, overnight at minus 20 c, forget it, won't start unless there is a defbrillator handy, minus 10 c 12 pulls...... minus 5 c... five pulls ????????????????????????????????
"Ride.Race.Live said:For me when I had my 00 srx running... it would be all relying on the tempuratures...
I kept the sled in a tempo so it was out of the wind but in the cold... would start in 5 pulls or more depending on tempurature... unless i get luckey.... if its warm... no second though it will start right up if i give it the right pull....
But when I go ice fishing and it sits in the open in the wind and everything its a soab to start.... and def follows the tempuratures on how many pulls or close to it! def looking in the 20's at times...
I havent had the chance to try out my 01 yet... but im curious to see the outcome
Though I have never have yet to date pour something in my cylinders or anything in those lines to help it start
Ride.Race.Live
if my sled is out in open after an hour it will def take alot... but as long there is still some heat around on it... its fine... if the temp stays around -10 or higher it doesnt take much to start for me... if its not in the wind! around 5 pulls on a usual cold day start.... but i guess this would all depend on the sled too.... not one is the same... engine wise...
well since a big gang of us have more or less the same symptoms minus a few luckey people out there im not too worried
fwiw....
this is my second 01, the first one, brand new, which was stolen, was the same thing.... a bear to start out of the box.....now I put a lightbulb under the hood with a blankie on my baby on those cold cold canadian nights......... brrrrrr......
Ride.Race.Live said:if my sled is out in open after an hour it will def take alot... but as long there is still some heat around on it... its fine... if the temp stays around -10 or higher it doesnt take much to start for me... if its not in the wind! around 5 pulls on a usual cold day start.... but i guess this would all depend on the sled too.... not one is the same... engine wise...
Ride.Race.Live
hahaha yea.... I would be kind of scared of that though!... lol.... i keep mine in a garage now... so its not bad compared to the tempo... but its just those nights that i go for a weekend that its outside....
My 98 started extremely easy the first few years. Then,almost like someone flipped a switch in the middle of winter, it started killing plugs when cold(over night or longer) starting. The funny thing is, its not the same plug everytime. Many times I have to change out all three before it will run.
After its running and warmed up, it runs and starts easy. I could leave it set for several hours and start it in 1-2 pulls.
Ive cleanned the carbs several times and no help. But I have never rebuilt the fuel pump .
I use the sled as a looner/spare sled now and noticed the last two seasons I havent had as much trouble as before. Hell, maybe it fixed itself!! Could happen!
staggs65
wish my stuff would do thatmaybe it fixed itself!!
hereismylife
Just thinking while reading. I am just throwing this out here to maybe help someone that don't know.
hopefully all of you know this about the choke. It has 2 positions.
1/2 is straight up
full is completely opposite to the off position.
Just thought someone might not know this...
1/2 is straight up
livewire_101proof
my 2000 srx has never had that problem, always running second or third pull, has been that way since it was new. I would agree to check the choke adjustment, make sure carbs are clean, also i have seen some of these sleds get so they will take a little more to start and are not as responsive if the reeds pettals are getting weak. Good luck.
jasonlmrx
my srx starts evry second pull with choke full on at whatever temp outside lol guess i got a good one
Jason.
Jason.
PhatboyC
For mine same day first pull all the time. After a week 5-7 pulls. First start of the season 100+ pulls. This year I tried rocking the primary clutch didn't help. After 100 pulls I got the plugs out, added some gas and it started first pull. My choke cable is adjusted properly. I looked everywhere to see the gas tank vent tube so I can pressurize it. Couldn't find it.
Which one is it?
Which one is it?
mopar1rules
just spray in a little starting fluid or gas in the cylinders. she'll fire right up.
doesn't the vent tube run up to the handlebars under the padding.I am sure it does.Mine also took about 6 to 7 pulls yesturday after a week standing.My SXR 2 pulls..go figure.
My 2002 SRX is a hard start after it has sat for awhile, my friends 1998 SRX starts without issues. If you look at the parts micro fiches for the 2000 - 2002 SRXs the fuel pump part number has been updated[backdated] to the 1998/99 SRX part#. As a point of interest...I put a 2002 SRX fuel pump on a SX700 Improve stock sled + now have a hard start issue on it as well. It may have something to do with that specific fuel pump??? I am in the process of freshening up my 2002 SRX...I may order in a new fuel pump[which is now the original 1998 part #] + see if there is any improvement.
that is interesting.Let us know what happens with new fuel pump then.
sideshowBob said:My 2002 SRX is a hard start after it has sat for awhile, my friends 1998 SRX starts without issues. If you look at the parts micro fiches for the 2000 - 2002 SRXs the fuel pump part number has been updated[backdated] to the 1998/99 SRX part#. As a point of interest...I put a 2002 SRX fuel pump on a SX700 Improve stock sled + now have a hard start issue on it as well. It may have something to do with that specific fuel pump??? I am in the process of freshening up my 2002 SRX...I may order in a new fuel pump[which is now the original 1998 part #] + see if there is any improvement.
Yeah, that is interesting. I know my 98 started great. My 00 is the total opposite. Let us know how it turns out.
Fuel pump
I think sideshowBob found a clue to the problem. In the Tech pages/engine/Viper fuel pump and oil line fix. You find out that 02 Vipers had the same problem, and 03 they went back to the old pump partno. I have a 01 srx and it started in 2-5 pulls first 2 years I had it, but last winter it needed 10-20 pulls everytime. I will make this mod to the pump and we will see what happens.
fortress
jkenosh said:my srx is a real bear to start unless you pour a little gas down each cylinder and than she fires right up, what is so different on a viper that they dont have that problem? i understand the basics pipes are different 3-1 yadda yadda yadda, i gues i want to know what i can do to get my srx to start easier like a viper does
Its a know problem.. MIne does that in cold temp or after a long rest.. Its not a carb cleaning thing!
tntmax
The 2001 srx came stock with a 40 pilot, the 98's had a 42.5 the mountain max had a 45 pilot, i just put 42.5's in my 2001 Srx 700 and it seems to be starting on 5 pulls rather then 12 so i hope its better,
tntmax
It is also a good idea to install a primer, that will be my next step....
