SnowBandit
I was drilling out my belly pan and went through the coolant hose under the clucthes with a small drill. I have a coolant heater to install... Could I simply cut out the drilled section and put the coolant heater there? Where is this hose in respect to the coolant system? Is it the return into the engine?
Or could I repair this hose some how?
Or do I need to replace the house? It was a small drill bit. Any help would be great...
Where would you guys put the engine heater? I couldn't find any good areas to mount it.
Thank
SnowBandit
Thank
SnowBandit
