Installing a can
Gagt518
Albany,NY
Bought an Bender can this weekend should be here later this week. Can i get a brief installation on how to install it on a SRX. Do i have to remove the 3 pipes? Thanks
YES, YOU WILL NEED TO REMOVE YOUR THREE PIPES AND STOCK CAN. NOW REMEMBER THERE IS A PIPE SEQUENCE FOR ON AND OFF ON THE SRX. I HAVE A BENDER CAN HANGING ON MY WALL , I LOVE STOCK MUFFLER. 3;16 (yammie tony)
put them on in the reverse order you take them off, they wind around each other and must go on and off in specific order, you'll see when you take em off just make a note of the order
Just bought the can to have some grumble in the exhaust. Always been a fan of the benders on the SRX's. And i save a little bit of weight also
Few springs here and there, couple bolts to loosen and she comes right off. 10 min job. Thanks. Now im wondering if i should change the gaskets on the pipes. $55 for 3 gaskets is awful pricey though at Yamahadirect.com
