Bought an Bender can this weekend should be here later this week. Can i get a brief installation on how to install it on a SRX. Do i have to remove the 3 pipes? Thanks
YAMMIEGOD3:16
YES, YOU WILL NEED TO REMOVE YOUR THREE PIPES AND STOCK CAN. NOW REMEMBER THERE IS A PIPE SEQUENCE FOR ON AND OFF ON THE SRX. I HAVE A BENDER CAN HANGING ON MY WALL , I LOVE STOCK MUFFLER. 3;16 (yammie tony)
Pipe sequence you say?
staggs65
put them on in the reverse order you take them off, they wind around each other and must go on and off in specific order, you'll see when you take em off just make a note of the order
Todddob
Go loud or go home!!
YAMMIEGOD3:16
NO, ITS MORE LIKE GO SLOW OR GO HOME. !! 3:16 (yammie tony)
Just bought the can to have some grumble in the exhaust. Always been a fan of the benders on the SRX's. And i save a little bit of weight also
YAMMIEGOD3:16
JUST BUSTING BALLS WITH YA. CANS ARE COOL, BUT I RATHER BE QUIET AND FAST THAN LOUAD AND SLOW. 3:16 (yammie tony)
Few springs here and there, couple bolts to loosen and she comes right off. 10 min job. Thanks. Now im wondering if i should change the gaskets on the pipes. $55 for 3 gaskets is awful pricey though at Yamahadirect.com
staggs65
better then blowing one out on the trail a mile from nowhere, been there done that, i'd buy em and keep a better of the old in your tool kit, or at least buy one and keep it with you, jmo$55 for 3 gaskets is awful pricey though
Yeah not bad of an idea
kirk700 srx
Im pretty sure they have numbers on the heat shields for putting them on!
kirk700 srx said:Im pretty sure they have numbers on the heat shields for putting them on!
What? You lost me on that one
Lightning Strikes Rider
Had a Bender exhaust can in the past they sound so awesome across the lake. Going to replace my stock set up on the Apex down the road. Good luck with your sled setting it up.
YAMMIEGOD3:16
WHAT YOU GUYS FIGURE A BENDER CAN IS WORTH ? HAVE A LINE ON A USED ONE. 3:16 (yammie tony)
