Viper_Jim
As The title says.....is it really this hard to remove the drive sprocket on my Viper? I've removed the secondary clutch and sleve to totally free up that side of the sprocket, I cant understand how to losen up the gear box side. I've removed all the gears from the chaincase right down to the bearing on the drive shaft, it moves back and fourth but I can't for the life of me figure out how to get the dam thing out?? I've started to remove the entire chain case, os this really necessary? Is there any trick to getting the shaft out?
