Yamaha 2000 plastic ski and vmx 600 xt
Ike
Finland
Hey
little advise with picture. Make hole to aluminium part so strut suspensions down part have enough space. And put 6 mm plastic plate between ski and aluminium that also too get more space under ski bolt. That was little advise, if u need more write to me and ask.....
ike
ps. and dnale, better late than never...?
Ike,
Thanks for the photo. Did you just enlarge the opening for the original ski? Then add a spacer between the mount and the plastic ski? Did you use the 96 version of the rubber mount/pivot under the strut?
hello again
there is no hole in the orginal ski (aluminium part) so i made it myself. plastic plate is between aluminium and plastic ski. That plastic plate lifts aluminium part 6 mm upwords. And i didnt use orginal rubber under the strut, i made a thinner one so that ski moves when u lift it from ski tip.
I drew a poor picture as you can notice i aint much of an artist. Did you understod what i ment.
ike
Ike,
THanks again! Did you have to add spacers/washers to the ski bolt to make the mount fit tight to the strut? This is way more info that I had 2 weeks ago!
Doug
Yes i
remember putting 3 washers per side so it is 6 per ski, then fit is tight. wider the washer better it is. I had to cut tube inside strut shorter to same lenght what strut is wide. remember to put grease inside tube. Zoom in pics you see much more.
ike
Sorry for my late response.
I just used a grinder. Clean and simple.
Ike
Again, sorry for my late response.
I don`t remember the exact measurements of the cutting. My sleds are stored for the summer in my dad`s place 110 km away, so ...
Just cut eneugh to fit the tss strut there. I´ll take measurements next time I visit my parents.
Ike
I got few requests about this ski thing, so I´ll just bump it to the top.
Ike
:yrules:
To the top. This is how the finished unit looks like. It´s sold now. We have long travel ´01 SRX 700 to replace it.
Ike
:yrules:
Ike- I wish you still had your sled...I just cant understand your directions but I am going to get a set of Viper skis and see what I can do with them. I just dont feel lilke have one of them fall off at 65...so any advice??
Ike i used an aluminum shim on mine makes it look nice and stock. and helped support the ski some more. When i get up to the cottage ill pull the ski apart and post up some info.
Dave, that would be great. I´ll try to dig some photos myself too.
Coles_55, sorry that you didn´t get any help from my instructions. EDIT seems to some pics missing. I´ll try and find those tonight.
Ike
Ike
PS I´ll try and find more pics.
Ike
"Make hole to aluminium part so strut suspensions down part have enough space. And put 6 mm plastic plate between ski and aluminium that also too get more space under ski bolt"
Ike
