03 Viper backfiring and engine warning light
powfinger
pennsylvania
Hello, I just got my 03 Viper out from storage and am having a problem. It will start but it backfires and won't idle and just stalls. I did start having problems last season with the warning light flashing occasionally. It seemed to happen when running it hard but didn't affect the way it ran. I attribute this this to rub through I've read about under the engine and that's where I will start. On the backfire/idle problem I did put new plugs in and nothing changed. Next I'm going to clean carbs and maybe adjust the power valves. Any other ideas out there? Thanks
Clean Carbs And Pvs No Escaping It Pre Season! Can You Get A Good Read On The Light How Many Flashes? The Flashes My Be Linked To You Powervalves.
I'll try to get the carbs done tomorrow. I couldn't get a read on the flashes as it always happened when i was moving along at a good pace.
just spent about 4 hours on the Viper. cleaned the pilot jets, all 3 were clogged. new gas, plugs, checked reeds, cleaned PVs, and pulled the wire harness to check for rub through. I adjusted the PVs also. The sled started up on the third pull and now idles. Everything seems to be Ok but I'll have to wait for some snow to see for sure. Thanks guys!
