ironman600
Can I run a 96 600 twin piston in my 98 motor?
mopar1rules
nope.
ironman600
Looks like my replacement piston is from a 97 not a 96. It is different in that it has a recessed notch on the pin sides that my 98 doesn't have. Is this still OK to use? Thanks
Both piston should be somewhat close in weight.
ironman600
Yes, they weight the same and measure the same so how could they not work. Must be just an updated design.
I had a 97 and 98 and yes there was a piston update in 98 if I remember right according to my dealer at the time.
mopar1rules
yes, '98 pistons were updated from the '97 pistons, which were notorious for the ring stop pin backing out, causing the ring to spin and snag on the exhaust port, causing all sorts of destruction. i personally would just get a '98 piston. your '97 piston would work tho, if you really feel like running it.
