viper crank
00sxrjoe
Maine
Ok i know it can be done. Put a srx crank in a viper. So I need some details. Can I use the srx base and viper top end? Or do I have the change that end brg on srx crank and put it in the viper case. Project i just picked up.
2000 to 2002 SRX crank will interchange in the Viper cases with no problems...but as far as I know the 1998-1999 SRX cranks don't fit in the Viper because of the differance in bearings. I am currently putting a Viper crank in my 2002 SRX.
Yeah the PTO bearing on the 98/99 are different than the 00/02
Yeah now on the cases I have to use the right case for chassis. Viper case with srx crank. Can I use a 00-up srx case and crank with viper top end.
viper
Have not bought one yet just wanted to know what will inter change.
viper top ends will bolt up w/no problems on '98-'99 cases, but the mounting location for the pickup coil is off on the '98-'99 case, which will be a problem for the viper wiring or '00-'02 srx wiring. also, the pto bearing on the '98-'99 cranks is different than the '00-'02 srx cranks and viper cranks, as already stated. viper top ends work fine with '00-'02 srx crankcases, as those cases are the same as the viper. then mounting locations for the pickup coil are right too.
