fortress
Quick QUestion, does the 2000 srx trailing arm fit the 2001 srx?
hotbeek said:They show different part numbers from 2000 and 2001
8DF-2382E-01-00 LH 2000
8DF-2382F-01-00 RH 2000
8DF-2382E-20-00 LH 2001
8DF-2382F-20-00 RH 2001
Part numbers may be different but still compatible ?!
crewchief47 said:Probably the same except for color. The 2000 looks to be Blue and the 2001 is Silver.
If the color is not a problem, make sure the letter stamped on the front of the arm is a "V" like the one you have should be. The letters are the key if color isn't an issue.
harness racer said:2-sxr v-max and venture are typical they have a diifferent camber
vince
