Quick QUestion, does the 2000 srx trailing arm fit the 2001 srx?
They show different part numbers from 2000 and 2001
8DF-2382E-01-00 LH 2000
8DF-2382F-01-00 RH 2000
8DF-2382E-20-00 LH 2001
8DF-2382F-20-00 RH 2001
Part numbers may be different but still compatible ?!
The only difference i could see is the decalc
can someone confirm if they are or not?
Probably the same except for color. The 2000 looks to be Blue and the 2001 is Silver.
If the color is not a problem, make sure the letter stamped on the front of the arm is a "V" like the one you have should be. The letters are the key if color isn't an issue.
i did find one on ebay and its a 2000 and its grey.. the sticker are not the same of my 2001. Its the only difference i could see on the pic
grey and black trailing arms are primered most likely by aftermarket co. " they are junk" the gauge of the tin is not up to yamaha standard ....you could not beat your worst enemy with one of them ....
1-srx trailing arms are all the same
2-sxr v-max and venture are typical they have a diifferent camber
vince
