yes pulls speedo side out of bearing holder and pulls the lower bearing out of chaincase. so easy to change track. i can do a track in about 1.5 hoursSno-Xr said:So, it pulls the drive axle in the direction of the chaincase allowing the speedo gear side to drop out of the tunnel ?
i would have to get someone to sketch it up for me? has anybody ever seen anything like this.maxwell said:How about a sketch with some dimension in case someone wants to machine one up?
it is metal.OnDaTrail said:Is it aluminum? It looks easy enough to make, especially since the slot has no purpose.
it does not have a number it is homemade.DARV said:I look in the catalog we have to order special tools it is no where to be found if is a Yamaha too it will have a number on it like YS-***** does it have a number if it does i can get the spec for it for you guys but I need the tool #
i would help you no problem if you were closer. and i could sell them just dont have the time to make them up.Sideshowrob said:So how much notice do you need to come help change my track? I will supply beer or whatever you prefer.
I like it. You should probably make a few up and sell them.
Interested in this question aswell.. If there is no problem with re installing the seal from the inside (never tried but I will today) this tool would be a great time saver!! Thanks for the post!!!and what happens to the lower chain case seal when you use this?
