99 V max oil pump adjustment question?
Z06 FAN
Ontario
Does anyone know how to adjust the oil pump on a 99 Vmax with 600 triple? The manual shows that you line up the marks on the oil pump for the 600. My problem is the pump cable looks like it goes down below the engine and you can't see it. The manual also shows adjusting the freeplay to 19-21mm in cable on the 700's. This is the way it looks like it should be on my 600 triple. I don't know, Im confused!
Thanks, I think I got it set now. My manual is not very accurate, I adjusted the free play in cable.
oil pump
Check the cable sleeve gap - there is a spec. to set the gap for adjusting the oil.
