Boost Bottle Fabrication
musselman
Sunderland, Ontario
I'm looking at making my own boost bottle for my sled. I have a question about the card boots, in the tech section there are some pieces that need to be made that go into them. What is the purpose of these? Here is a pic of what i'm talking about.
The rings that you are talking about are to take up the space between the intake boot and the carb because the boots are actually for a larger carburetor.
A way that I DO NOT like.... They instruct you to use silicone sealant(rtv) to seal the carb rings to the carburetor, then install the carbs into the boot. To me this is a burndown just waiting to happen, but it is currently the only way to use existing parts to help a boost bottle fit onto a triple. In my opinion this type of engineering is great for the race track but not good for a woods rider- if you know what I mean.
Hmm...... yah that's just a burndown waiting to happen, not good for reliability. I would think that a tight fitting rubber ring would be better than that, but it may not slide in to the boots as easy. I will have to try some stuff out and see what I can come up with. Thanks for the info.
Max I understand the principle but I am just the type of guy that likes to have a known gasket or mating surface in the intake tract rather than using a makeshift type gasket. I guess that I'm to into doing it the right way.(so to speak) T
max is correct , red locttite no leaks , and yet to see burndown due to that , seen burndowns cause fellas used hose clamps on boots " sorry Bob "
those rings fit in the boots extremely tight you will need screwdrivers to get them out after awhile
