700max
I've got a 00 v-max 700. Basically stock just reed spacers and played with the clutches a little. Just got a set of psi pipes and was wondering about some help with jetting and clutching. Jets are stock and it's time for the clutches to be re-built so I am looking for some good input as to what to put in it for springs and weights. I have reason to beleive the primary clutch may be a stock MM 700 clutch but that was dome before I got the machine. I would like to pull some good performance but trying not to loose all the fuel milage. I know the pipes won't help but, I would like to see how If I can beat up on a few of my buddies.
Tuning with trip pipes and clutching to match WILL drop fuel mileage in the shitter,check tech pages on top of the page look for members set up's.
or try searching....im a stock guy cant help ya welcome to the site..
700max
ya i figured it would drop fuel mileage, but I'm gonna try it any how. I will look there.
If you can get a short cover for your clutch, I have the psi specs for the clutching. otherwise its an iffy proposition.. maybe someone on here will have a good setup for the tall cover ,we had a hard time trying to dial in the tall cover and psi was no help to us.
700triple
What is your gearing?
