ryanryan
I just want to make sure I have everything right before I go out and by the products I need.
- I plan on using a Scotchbrite pad and some paint thinner/brake clean to remove all dirt, grease, grime....etc.
- I am then going to use some NEVR-DULL to polish/clean up the tunnel the best I can.
- Then I am going to use Mothers MAG and Aluminum Polish on my Powerball Mini.
- Then I am going to finish off with Mothers again, by hand.
So, I have to get: NEVR-DULL, Mothers MAG/Aluminum Polish, and some terry cloths. Anything else?
Depending on the results I get/how long it takes, I will also clean and polish the Yamaha pipe cover, and belt cover, and see where I go from there. I will also take lots of pics to show others wanting to do this my results.
P.S. I did a search on this topic and got some of the techniques needed for good results and this is basically all the info. summed up, and I just want to make sure I'm not missing anything. Also, sorry for the long post!!
