JordanHall488
hi,i got rail extensions an a 136 track for my 91 phazer 2...will i have to extend the tunnel? anyone ever made there own tunnel extension?
thanks everyone
thanks everyone
nitris223 said:Stock suspension but we made some rear drop brackets. The old phazers would always drag the snow flap. I raised it something like 2 inches which is just about right. You can see the brackets a little bit in one of the pictures. The extension was made out of steel and for the roll on the edge I found a piece of pipe same outside diameter as the tunnel and turned it down on my lathe to just fit snug inside of the factory rolled edge and then welded it to the extension. This added extra support for the extension when lifting the rear of the sled. You could make the same out off aluminum ,which I wanted to do but at that time was unable to weld aluminim. I think I still have the templates for the drop brackets if you need some measurements.
