Vmax tunnel protector
sbsho
Chicago/Jacksonville
I currently have a 95vmax 600le with 3in drop brackets on the rear. i am picking up a camoplast 136x15x1.25 that has 144 or 196 studs in it, cant remember, for real cheap. i also just purchased 8t drivers and im ordering rail extensions next week to extend the 121 skid to 136.
Now will i be able to install my 8t drivers, extend the skid and put on the track with no issues? Now does this sled have tunnel protectors on it? And will i need them even though im putting in 8t drivers? If i do need the protectors which ones should i buy and how many. If someone has the same or similar setup with pictures it would be great to see. thanks
My 95 600le didn't come with a front cooler or protectors. Can someone confirm that the electric start models came with no front cooler?
My 8t drivers work great. Your stock should be 21/37 1.76 ratio. After 8t drivers you should be around 1.99 ratio. Which is still not bad. I felt this machine was grossly over geared anyways.
