To bypass the tors do I just unplug the wires and plug them back together?
Yes but this is definatly not a permanent fix, you must find the problem and correct it, never knows when this could save a life or a sled. Easy system to diagnose, test the shitchs for continuity...
mulderdad
I have always disconnected the tors and never worried about it.
There is this little button on the handlebars that is red and if have a problem you just push it down.
staggs65
x2 also a tether is good protection too
keep tors working...
IF your still on your sled and hopefully it's not WFO heading tward someone.mulderdad said:I have always disconnected the tors and never worried about it.
1995vmax500le
i made a new throttle block for my viper and dont want to use the stock kill switch and it has the TORS on it for the throttle override connection. How do i get around this? do i just cut the wires from the kill switch and then cross them or what?? cus the wires need to plug into the plug under the handle bar pad.
mulderdad
Got a tether also for that. lol!
